Does anyone use plain new 5W30 motor oil as bar oil when cutting at temps below 15 degrees? I used R&O hydro oil last time when cutting in these temps and it worked fine, but I'm out of it. What do you use for bar oil at these temperatures?
I have a strict policy of never cutting wood at temps below 15 degrees
Straight canola. Learned that on here, cheap easy and non toxic. Cut a bit the other day at 20 F and it was fine.
Yes . Used cooking oil filtered works well filtered. In cold weather I'd advise not using it or mixing it with dino or it will gel up.To go one step further, would used cooking oil work if strained? Or not enough slippery stuff left in the oil then? I dunno if I'm that cheapto try used, but I'll try new canola oil.
I use winter bar oil. Tends to go on sale pretty cheap here at Canadian tire in 1gal jugs.
8-10$ if I remember correct. That's when they have a sale at my local not sure about other locationsFunny thing, I'm looking online and the 1 liter bottles are $3.79, but I'd swear the last few times I've bought it, it was at least a buck more. What were you paying for a 1 gallon jug?
