I don't grease. Bar lube gets there. Most modern bars don't have holes to grease. Like auto ball joints, I think they found that grease is good but the hole lets in more dirt than the greasing helps.
I have read, and it makes sense, either grease or not, but once you start greasing, have to keep doing it. The grease forms an outer dam and the bar lube can't get in there so if you stop greasing, it can damage the bearings. I'd think the grease needs to be fairly thin. #1 or #0, not the most common #2, but check your owners manual.
I have an almost unused greaser if someone wants for the price of postage. Although I think they are really cheap, maybe cheaper than postage.
Sean - you may want to use a lithium grease. It doesn't harden up over time. I've seen it in 3 different colors. Dark grey, white and burgundy. I like burgundy. It looks cleaner longer. My only complaint with it is that during below freezing temperatures it gets tacky until it warms up.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
