CTwoodburner said:
bogydave said:
I don't think the oil was dulling the chains.
Have used plain clean/new 30 wt motor oil for years, never dulled a chain (from the oil).
Adjust the oiler setting to max, fill the oil, & fill gas 3/4 so there's oil left in the saw when it runs out of gas.
The Chain cutting teeth are not in the oil, dirt in/on the bark, nails or hitting the ground etc. dulls the teeth, not oil.
Many saws hold enough b&c oil for two tanks of gas.
When I get a newer model saw, newer than 27 years that is. I'll look for than feature. Replaced 1 bar in 27 years. Average 10 cords/year & miscellaneous cutting.
I guess if I was using Stihl or Husky bar oil, I my have replaced 1 bar in that time.
When I bought the saw I'm not sure they sold "special formulated" bar oil. Book recommends clean 30 wt oil. So thats what I use/used mostly.
But in a pinch, used motor oil, maybe that's why I had to replace the bar,
(or maybe when it got stuck, the tree was the wrong way, I ran, saw flipped under the tree, bent the bar)
How much $$ is a gallon of c&b oil anyway? I've never bought one. (online: saw husky bar oil for $11.95/gal)
I was lucky, I drained empty 55 gallon drums (30 wt diesel engine oil) before we crushed/burned them, saved the oil in 5 gal jugs, have 15 gallons still.
Nice thing is , if you use high dollar brand name bar oil, it's good for the national economy & good for your saw.
If you don't & that's OK too, it's good for your economy & probably OK for the saw.
![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
