Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
looks like the board is dead in my old shop stove. when i plug the room blower into the auger ports it works.is this fixable or is the board fried? it was running fine for a while than just died. thanks
I'm not sure about the older stoves, but my newer (2008 or 9) PDV did the same thing, blower motor wouldn't run, but would if I plugged it in to another port (I think I may have used the auger as well). Turns out I had a bad opto. Replaced it and all is well again. But, as I said, I haven't looked at a board from an older stove, so I don't know if they're the same. That said, the part was $4, and I soldered a Zero Insertion Force (ZIF) socket to the board should I need to replace it again. Best bet would probably be to call Englander or hope that Mike from Englander might see your post.
Agree, it's probably a bad triac or optoisolator. Cheap parts, but you have to be able to solder/desolder on the circuit board. Even if you have to pay someone a few dollars to do it for you, it'll be cheaper than a new board.
Eric, your avatar looks a lot like a Cub. I have two and love 'em!
I think I got them from a place here in Portland called HR Distributors. But, as was posted above, any electronics retailer or Mouser or Digikey should have them.
i have no problem soldering so i will give it a shot. yes it was on a surge protector.i bought the stove used and just cleaned it and re sealed it and its been humming along ever since. i was shocked to see it not running. thanks
I'll caution you to be very careful. These are surface mounted (not through the circuit board) and the soldering pads and traces could come up very easily.
went to the shack today and all they had were the triacs. they had a few differnt types. i couldnt read the writing on the old board which one should i be looking for? phil
