Meant to test my Enviro Empress Insert to see what happens, when the power goes off. Did not have to! Today,we had 4 seperate power outages that lasted less than a minuite each.
( this is common around here, just forgot about it). Well, the stove did not smoke at all with the 25' 4" flex liner. It did shut down totaly.
What I'm looking for ( have an emg generator ) is a UPS unit or whatever, that would kick in right a way so the insert would not go out.
The pia with the empress is the #2 light blinks, indicating a fault trip. You have to pull off the surround, pull the stove out a bit, reach or squeeze into the back and press a reset on the High Limit Temp sensor.
Wife can't do that alone and it is a pain.
Searched and found information on inverters, generators and battery After the power fails, but is their something relatively inexpensive that would suffice for momentary outages?
Thanks
Thanks
