I lit up our wood stove for the first time this year and had quite a surprise.
First off it seemed a little smokier than usual and close inspection revealed some smoke was indeed leaking out. There was a decent pull of air up the chimney (sleeved and piped old fireplace), nothing less than witnesses in past seasons, nothing odd.
As I sat in front of the stove and continued to inspect it in an attempt to discover the problem the lid suddenly blew off the stove a good few inches and made me jump. I extinguished the fire and will not be re-igniting the stove until I discover the problem.
Information on the stove, etc:
The chimney is sleeved, piped, and capped, and has been for the 5+ years I've owned the house.
I had the chimney inspected and re-capped 4+ years ago as well as the old one was leaky and sub-standard.
The fireplace was not in use before by the previous owner. The bottom of the pipe was sealed.
The stove has been in use for 4+ years, and is a hand-me-down no-name cast iron stove.
As the chimney is capped I cannot see how there can be any blockage.
It was not windy last night, so I cannot see that as a problem either.
Any ideas what I should look for next?
I cannot afford a $1200+ insert and the room is too small for any stoves I have seen so far, so if I cannot resolve the situation I will probably seal the fireplace.
