Back to the drawing board. Tank Design
henfruit
I met with the person who would build me a tank. I told him my concerns of the amount of pressure it willneed to hold. H e said he would like to have the main body of the tank built in one piece bent into a u shape then add baffels corner gussets t. then recease the ends in to get a good weld then add the top. my question is would this design add strengh to the tank. he also mention useing 3/16 stock. thanks agin for the imput. pat.
Have you looked for a used propane tank? They are usually 5/16" thick and have tappings all welded in. I had mine given to me. I think if you look around you can find one for a reasonable price. You can buy brand new propane tanks from a supplier like FW Webb.
Hi Hen, I talked to my guy today about the same concerns and he said to do it right would be a little more than he is prepared to do. Also, with the concerns about corrosion with an aluminum tank, I am starting from scratch too.
I actually think now I could put a tank in my garage. I have a big 3 car garage that we only use about 1/2 of . I think I'll call our local propane suppliers next week and see about a 500 gallon tank. I kind of like the look of that New Horizons rectangular tank too. Anyone know what they cost? I probably don't want to know ! LOL
As far as the propane tanks, can you cut holes in them and weld fittings on them? I would think you have to for a pressurized system?
thx, Pat
Pat,
The propane tanks have some ports in them when you get them. If you need more you can drill with a bi-metal hole saw and then weld in a weld o let or pipe. I just filled mine to the top with water to flush it then I let some out so I could weld in my fittings.
Rob
My problem is getting it in the cellar.Only have a 36 inch door. I should of put in a bigger one when i replaced the slider.If my boiler room was bigger it would be nice as the boiler room is at 100+ all the time.Or i could expand it but then cut down on wood storage area?? Windy ridge supply has a nice tank tall and thin with 2 heatx built in them but the price is 4500.00 and the volume is 350 gallons.
I don't get a good gut impression of your tank builder. Maybe I'm wrong. My tank that has A516/70 pressed heads & rolled A36 main body is 3/16" thick & this is good to 60 psi. This is a tank that has the forces spread evenly. I would think a rectangular tank would need to be thicker. I'm going to call my tank builder for you & see what the experts say. I'll be back, Randy
Why don't want to you use a non-pressurized tank? You could assemble it in the basement. If and when I get storage I think it will be non-pressure, either one I build or a commercial one.
Doug
