I got the "building bug" again and off on another pellet stove control panel crusade.
The controller I built a while back for the Prodigy works fabulously, and so the next step was to build a unit for the ADV 2 T
The big Whit is a tad more complicated in that it uses a few different types of controls and has some slightly different needs.
The current controller (Factory unit) has never been quite right, in that the room air fan runs at near full speed with the control knob doing little if anything to adjust the speed.
The exhaust/combustion blower speed also is not working as the spec's say (Voltage on low feed is a lot higher than it should be) but it has done the job OK since 2010 when we got it.
Soooo
I started gathering components to build a completely new controller from scratch.
New control box (Bigger than the one used for the Prodigy 2)
More solid state relays to allow better safeties and far more control.
Adding a pressure switch that will shut the feed off if the room air fan stops
Adding a vacuum switch to shut the stove off if the draft/comb fan stops running
Adding various LED panel lamps to indicate various functions and allow quick diagnotics.
Changing the HIGH limit snap switches out in favor of manual reset type to make a restart impossible without investigating why it shut down.
All sorts of goodies to update this venerable old girl.
Here are some pix of things so far.
Many small items still coming in the mail, so work is slow to be sure things all fit where they need to and work like they should.
Getting things all done a bit better than the one on the P2
Easier access to the inside of the panel with the two black thumb screws at the top.
A stove mounting bracket.
As soon as all the holes are drilled for Switches, knobs, controls, led indicators, and the internal components the beast is going to get a complete paint job to match the stove. (Metalic gray Stove bright)
I sourced relays and things differently on this unit and this will help the time frame some on the build.
The one piccy with the one meter in the panel and marked up green tape has all the different control locations marked and ready for drilling.
One more meter still coming as are several buttons and such.
The meters are for the two fans (Combustion and Convection) and each will have a control pot mounted close by (between the meters) do vary the voltage/speed>
To assure that the fans do not accidentally get set below the factory low setting a fixed resistor will be connected in parallel with the pot to keep the lowest speed as a given.
The draft/comb fan requires a 70 volt low setting minimum and can be adjusted up from there
Room air fan will be adjustable from about half speed up to full speed.
Most fan speed controllers have an off setting which I wanted to avoid.
Going to use Infitec phase speed control 2x2 solid state controllers in the system.
I have had a few ask me WHY ????
The factory controls are very spendy to replace, and are very delicate.
The micro electronics will not handle any abuse (voltage spike due to power outages etc)
The new controls are all rated at far more amperage than will ever be needed (20 amps)
Very robust and IF there should be a timer/relay failure, it can be replaced in only a few minutes
All the internals are hard wired and with 14 gauge wire, which is way more than needed.
Will post more as it happens
Soooo
