HI! I have been lurking on this forum for a while and found loads of helpful info thanks.
I have not seen this item covered elsewhere:
This is a new install.
I have a rear-venting Baby Bear, 6" (6" outer diameter, 5 3/4" inner) which will not mate well with the double-walled Duravent DVL 6" "T" (also a 6" outer diameter).
I was assured that the DVL would fit, but alas it does not. (same outer diameter).
Duravent does not appear to have an adapter, and It feels wrong to try and crimp the thinner inner layer of the DVL T and force it into the flue? I suppose I could do that and apply a healthy bead of chimney cement?
Any advice? Again apologies if this has been covered - I could not find.
