Avalon insert question
hvsk
1
california
Avalon fireplace inset wood stove came with house. Damper lever is up/down on bottom right side of stove. Which direction opens the damper?
Welcome. Most Avalons have the air control in the front, bottom center. The air control is pushed in for more air to the fire and pulled out to reduce air. Can you post a picture of your insert so that the model can be identified? A second picture of the control location might also help.
So this is an old Avalon before Travis industries pitched them. I assume that because I've never seen one that wasn't front and center on the bottom of the unit.
Might be a 996 which was 1980's model under Travis.
Is this air control location in question? Click image to enlarge.
My dad has an older Avalon. Moving the lever up opens the air, down closes it. He bought it used around 1992ish.
