Hello to all. I have an Avalon Astoria PS. I recently changed the door gasket and am curious if I should have adjusted the door prior to using the stove with the new gasket. The door latches seem to be very tight with the new gasket and on the latch side the door gasket now has an indented shape. The other three sides seem to be ok but after 7 or 8 hours the pellets are filling the fire pot and extinguishing the flame, so I'm thinking that there is still an air leak.
I've cleaned the stove removing baffles, fire brick, exhaust and combustion blowers and blower boxes and cleaned the exhaust but the pellets keep piling up. Also, I've cleaned behind the refractory as well. To me,
the issue is either the door needs adjustment and or another door gasket. I've read the Avalon Astoria manual and the door adjustment procedure is kind of clear, however I'm not entirely sure if after replacing the door gasket its standard to readjust the door. Any advice is greatly appreciated.
