A loose limit switch would definitely be the cause of the stove shutting down. If the switch by the convection fan doesn't stay hot enough (120
![Fahr ::F ::F](/talk/styles/default/xenforo/smileys/f.png)
), the stove will 'assume' that it ran out of pellets, the auger will stop feeding, the stove will burn down, and the combustion blower will eventually stop.
My guess is what you were probably hearing was the screw that holds the limit switch rattling around in the fan. If you can locate it without removing the convection fan, reinstall it to fasten the limit switch to its mounting, and you should be good to go. If you can't find that screw, here's what I suggest to ensure that the loose screw isn't stuck in the convection blower housing (since you've already removed it once, much of this will be familiar to you):
**POWER DOWN THE STOVE AND LET IT COOL, UNPLUG THE STOVE**
1) Get a set of male/female 'handclasp' crimp connectors from a hardware store. This step will help with future maintenance.
2) Install the connectors ~3" before the convection motor so that you can easily remove and replace the convection fan without having to pull the stove out from the fireplace to access the connectors at the terminal block at the back.
3) There are two sets of sheet metal screws holding the convection fan assembly to the bottom of the stove. Two screws hold the bracket that the fan itself is mounted on, another two screws hold an air guide plate on, and you'll see that they're slotted to allow the plate to move. Loosen the air guide screws (but don't remove them), and wiggle the plate forward to allow enough clearance so that you can then remove the screws holding on the fan assembly and slide the entire convection fan assembly (housing and the bracket it's attached to) out by way of the left hand side.
4) Check the convection fan assembly for the loose screw that was holding the limit switch on. If it's not there, check the bottom of the stove and elsewhere. Shake the convection fan assembly to be sure the screw didn't actually fall inside the 'squirrel cage'.
5) If you have found the limit switch mounting screw, reinstall it on the right side of the stove to re-mount the switch. If you have not found it, go to the hardware store and buy a replacement, using the remaining screw that's still there as an example of what you need to find. It's a machine screw that (if memory serves) is 8x20 or something like that. Lowes or Home Depot will have what you need.
6) Re-mount the limit switch (if you haven't already done so), and reinstall the blower assembly by sliding it from the left to the right, tighten down the sheet metal screws, push the air guide back into place and tighten those screws, reattach the electrical connectors (now you know why we did that little thing in step 1) and restart the stove. Optionally, you can directly power the fan if you want to test it before starting the stove again just to be sure nothing else is stuck.
Hi,you got it backwards,the switch on convection fan is the high limit shut down.The switch on the combustion blower is the 120 switch,acts as a proof of fire switch.Same on both version stoves.The convection switch held on with one little sheet metal screw,known to come loose,would not matter if it fell off(no electrical ground on these switches,is why they have 2 wires}except may not be in the airflow properly.
That should get you going.
