Nice stove.........
may depend on software # but here is what i have
depends on it the stove is flashing or remains on.
flashing auger off system good...
remains stove shuts down.
i assume stays o9n because stove off.
er2 overheating. i would reset it and see if works
er0 low exhaust gas temp , missing pellets fire out
er1unacceptable config of auger parameters
er3air flow, door gasket, burnpot dirty, intake exhaust etc
er4air flow too low increase fan rpm
if reset doest work try high limit switch........
good luck
Stove is completely clean , flue clean
Stove has been working overtime , temp hasn't gone above single digits in a few days.
Just cleaned the hopper, seemed to be an inordinate amount of fines
Will test the high limit switch , maybe it is an overheating issue
Still curious as to what error code 2 is.
Nice stove.........
i assume stays o9n because stove off. er2 overheating. i would reset it and see if works er0 low exhaust gas temp , missing pellets fire out er1unacceptable config of auger parameters er3air flow, door gasket, burnpot dirty, intake exhaust etc er4air flow too low increase fan rpm
good luck
