Austroflamm integra insert auger stops after igniting
Bill Kennedy
27
NW CT
austroflamm integra insert. Stove starts normally but right after igniting the auger stops turning.
Then runs out of fuel and error shows as out of fuel.
Stove is clean, high and low limit switches have been replaced
Cleaned out auger to make sure no jams
Any help or suggestions will be greatly appreciated
Airflow across the air sensor keeps the auger running.Try cleaning it.Other things-bad leak from door gasket,bad sensor,combustion blower stopping(which could be from control board),bad control board.Oh,restricted/partially plugged stove,flue and/or air intake can do this also.
