Austroflamm Integra II-holes? surge protector?
northwest
4
OR
Wonder if any of you owners can help me. I will be getting a great deal on a floor model. They no longer sale Austro, so they don't know the answer to my questions. Here they are: 1. Can I use a surge protector with the Integra. 2. The removable oval like shelf, that you take off to clean the heat exchanger tubes has 2 large round, machined holes in it. Is this normal? Or is something missing? I was wondering if there is a mechanical reason for the holes. if so what are the reasons other than to remove the shelf and Can I make a ceramic tile to cover the shelf? The dealer said he would get anything that was missing, but how do I know??? I'm asking for a manual, a DVD and the missing piece, if it is missing. Do you folks know of anything else that you got with your stove? Any info would be appreciated. Thanks NW
I'm not all that familiar w/ the Intregra II (although I almost bought a new one this summer, but too $$ for me), but as for the surge protector, I just put a thread up tonight on that very subject.
Yes, you can run any electrical device like a pellet stove through one, andI highly recommend doing so....here's the one I bought...it's inexpensive, but provides good protection to the electronics in our stoves:
www.radioshack.com/product/index.jsp?productId=2454735&cp;
It says out of stock online, but check your local Radio Shack.....they should have them.
They don't give to much info on the specs for the Radio Shack single surge protector, I personally like APC or Tripp-lite. They cost a little more but I know they work I have seen an APC take a lightning strike and not let anything through. The surge protector was toast but the equipment was not harmed. Do you know if the hot, neutral an ground are protected?
Here are the specs for the Isobar Surge Suppressor Model #: ISOBLOK2-0, sells for around $20 - $25.
SYSTEM OVERVIEW
Voltage compatibility 120 VAC
Frequency compatibility 50/60 Hz
OUTPUT
Output volt amp capacity (amps) 15
Output watts 1800
Outlet quantity / type 2 NEMA 5-15R
INPUT
Input connection type NEMA 5-15P input plug
Input cord length (ft.) Direct plug-in
Recommended electrical service 120V,15A
LEDS ALARMS & SWITCHES
Diagnostic LEDs PROTECTION PRESENT (green), LINE FAULT (red) and LINE OK (green)
SURGE / NOISE SUPPRESSION
Protection modes Includes full normal mode (H-N) and common mode (N-G / H-G) line surge suppression
AC suppression joule rating 600 joules
Clamping voltage (RMS) 140V
AC suppression response time NM = 0 ns. CM = <1 ns
AC suppression surge current rating 48,000 amps
AC suppression components used Metal oxide varistors, toroidal balanced chokes and VHF capacitors
Safe thermal fusing Prevents unsafe conditions during extreme extended overvoltages and catastrophic occurences
UL1499 let through rating 330V - UL verified
EMI / RFI filtering 40-80 dB
Immunity Conforms to IEE 587 / ANSI C62.41
PHYSICAL
Unit Dimensions (HWD/in) 4 x 2.5 x 2.5
Unit Dimensions (HWD/cm) 10.2 x 6.4 x 6.4
Material of construction Metal
Form factors supported Direct plug-in format with retaining bracket supports wall mounting directly to a standard AC wall socket
Housing Color Light gray
Receptacle Color Black
CERTIFICATIONS
UL1449 1998 Rev. (AC Suppression) UL1449
UL1283 (EMI Filter) UL1283
cUL / CSA (Canada) cUL
Approvals Exceeds IEEE 587 category A&B;specifications
WARRANTY
Product warranty Lifetime
Connected equipment insurance (USA and Canada Only $10,000
Overview
Style Direct plug-in
Great info, on the surge protector. I like that it is direct into the wall. I'm still wondering about the holes in the lid/shelf. now I wonder if the ceramic coating is missing. I don't see the holes on any of the pictures of integras? well if anyone else has a stove like this, let me know.thanks!
I have a new integra - not sure about a surge protector - but why not - can't do any harm - will it help? maybe , maybe not. As far as the removable shelf - I think it is purely decorative - its color should match the color of the side panels - I would insist on getting the correct replacement piece. Make sure you get the rod that latches into the holes for cleaning the exchanger tubes - it will be the only way to easily get at them - it also comes with a potholder mitt so you do not burn yourself. My first season with this unit and pellets in general - however using it the past two evening I can generally say it seems great. One thing you should consider : is there another dealer close by who can service your unit? Don't forget - these are made in Austria - so if you do not have a dealer stocking parts that is in your area just in case you ever have trouble - you may want to keep this in mind.
Disclaimer - My Integra II is sitting in front of my tv and will not be installed until I complete the hearth pad.
1. I fully intend to use at least a surge suppressor, or possibly a small UPS if I can find a full sine wave one that is inexpensive.
2. the 2 machined holes in the top shelf are for pulling the cleaning rods for the heat exchange tubes. Using the hook/handles provided, you would hook the heat tube cleaning rods through the machined holes and pull them up and down. You can download a copy of the information manual and other stove info here:
(broken link removed)
3. here's what my stove came with:
stove. burn pot. gray color top shelf with holes. gray color side panels (2). instruction manual and documents. 3" aluminum couplingto connect to chimney (please not that this has a special angle for corner install). clamp for coupling. 14" long rod that I think is a burn pot scraper. hook to pull heat exchange tubes. stove mitt.
I didn't find the dvd
Good luck
Eddy
If I am picturing this right, you have 2 holes on top which should house the metal rods to clean the exchanger tubes, like jumpinin said. If you don't have the rods, then you can't clean the exchanger tubes, which would be a problem. So the holes are not decorative but a necessity!! After you make sure you get the rods then get the the tool that is used to clean them as well as the oven mitt.
I have used my Integra II for the past few nights and only at 10%, 2 story colonial with 7 rooms (4 bedrooms) and the downstairs has been at 75 while upstirs has been at 74...the bedrooms are closer to 71 all without ceiling fans going yet. So I am very happy with our "investment" ;). I have a full tank of oil for the hot water and I would like to see Feb before I call for a delivery.
Good luck
Eddy
Did you get the decor plate that goes on top of the stove just ahead of the pellet lid? The two steel pegs are for holding it in place. This plate goes around the two cleaning rods.
Thanks to everyone for the information! I got a removable plate with the 2 holes to reach the cleaning rods. They are ordering the poker for me. Is there another decor plate that covers the holes? Thanks
NO, THE TWO RODS HAVE HOLES IN THE END AND ARE EXPOSED SO YOU CAN INSERT THE ROD TOOL THAT COMES WITH THE STOVE FOR PULLING THE RODS UP AND DOWN FOR CLEANING. THE DECOR PLATE IS DESIGNED TO GO AROUND THESE RODS.
I THINK AUSTROFLAMM COULD HAVE BEEN A LITTLE MORE IMAGINATIVE AND MADE THIS AREA A LITTLE MORE ATTRACTIVE SINCE IT IS SUCH A VISIBLE AREA.
THEY COULD HAVE ALSO PICKED ANOTHER COLOR OTHER THEN GRAY FOR THE BASE OF THE STOVE.
AUSTROFLAMM SHOULD TAKE A LOOK AT THE 1996 LOPI FOX FIRE FOR SOME IDEAS.
JUST MY OPINION.
JUST MY OPINION.
You don't have to YELL....please type in lower case...thanks.
JUST MY OPINION.
That is not yelling or any intention there of. It is simply larger type to allow the viewer to not have to strain the eyes.
Notice how much easier and less taxing it is to read over the message when picking out certain points of interest.
I don't know how familiar you are with your browser but if you have difficulties to read just make the font a little bit larger.
Let us know which browser you have and we will help you to change it to your likings.
Nothing personal, but if you write in Uppercase it is considered yelling on any forum you participate.
If you like to emphasize on anything use the bold, [strong]strong[/strong] or [strong]italic [/strong]code in your writing.
This forum is powered by expression engine which i use on my site too and allows quite a lot of html code to be used without yelling.
Now enough of picking on you. Hope the above helps you.
