Hi, please help me I have been having trouble getting my Austroflamm Integra (1998 model with self ignitor) up and running for almost a year. But I’m still not giving up ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
The problem started when the low limit switch died (fall apart) and I replaced it. (bought two pieces)
The low limit switch dies every 3-4 years so I already knew what to do. After replacing it then stove goes out after the starting procedure. Tried both new switches and also bricked the wires – no avail.
The starting procedure is fine. Fire burns good.
After the starting procedure (about 16. Min) the combustion motor goes out – very slow and then eventually stalls. If I take one wire from the low limit switch and put it back on, the combustion motor goes on for a second and then goes out again. If I do that the auger motor will also go on again.
I checked the wires they seem fine. The control board seems fine also, no burnt parts or anything.
Where is the convection fan and what does it do? Maybe the air flow sensor is faulty?
Please help!
Please help!
