Hello all,
Kevin here from NE Pa. So its a cold time for my stove to stop working lol. I have a Lopi Yankee pellet stove and have had it for 17 years. I have replaced the auger motor maybe 10 years ago. I replaced the exhaust blower 1 1/2 years ago. That's it and it has run fine most of the time. About 10 days ago I noticed a lazy flame and shut it down to clean. I usually do a good clean once a week. Started it up and it turned on but no pellets from the auger. I bench tested my blower fan and auger motor. They each tested fine. I blew out the tube that connects from the pressure switch to the exhaust fan. It was clogged but I cleared it out. Figuring that was my issue I put it together and it whirled into action. It seemed to take a while for the pellets to begin to drop though. Within 3 days the lazy flame returned and I cleaned it the 4th day. Checked the tube it was clear. Put it together and turned it on. No pellets from the auger and I got the auger fault. The auger on light went on but no movement. I turned off the stove and bench tested the auger it in its place. The motor hummed but would not turn. It was working a half hour earlier.
So my question is, is my auger motor on its way out? I thought the first time the motor got stuck by a pellet but not twice in 5 days. I've never had a pellet stuck.
Thank you in advance for any guidance. I just want to be reasonable sure it's the motor before I replace it.
Kevin
Kevin
