The auger on my pellet stove is very noisy. The noise is like a big groan. I originally assumed that it made this noise when a pellet was in the auger the wrong way and it was being ground up. However the noise is often so recurring that I am assuming that something is wrong.
This noise does not occur all of the time. Sometimes it will run for 30 minutes without the groaning noise. However often it is so constant, that we have to turn it off in order to sleep.
I ran one experiment to see if perhaps something is causing the auger to grind up a lot of pellets. I put a piece of aluminum in the hopper above the auger opening to control/slow the entry of pellets into the auger. This has greatly reduced the number of groaning noises.
Has anyone else had this problem of excessive groaning noises from the auger?
Any suggestions on what the problem may be?
Should I elect to take the auger out to check it, does anyone have instructions for removing it?
Thanks
Thanks
