I have a Harman Accentra 52i for about 8 years now. It's been a great investment, but just in time for the sub zero temps, it's giving me issues.
It starts up and feeds the pot for about three minutes, but does not fill it like it usually does. Then it stops feeding and comes on intermittently every 30 seconds for only for about two seconds then turns off. I replaced the auger motor which was leaking and I thought that would do the trick, but it didn't. I read on another thread here that I should try troubleshooting by bypassing the pressure valve, which I did, but the same issue occurs. I swept the chimney prior to that and the stove is in good clean condition. Are there any other sensors I should be looking at that are attached to the control board ? Does this sound like a new control board issue? I'm lost at this point...
Thanks in advance for any help!
