vacuum hose is clear as well.
it's a heatilator ps50 and it was working fine tonight.
i vacuumed out the auger channel, stuck a wire up to unjam any possible upper auger jam, i even loosened the mount screws on the motor and moved the auger itself up and down to free any jam.
the vacuum line is clear.
call light on the control box flashes blue. i tried the reset and no motion on the motor.
i even hooked up my spare motor and it also did not turn.
at this point i'm wondering if the vacuum switch might be bad. do they go bad?
oddly, when i removed it, i see a hole in the soft diaphragm looking part.
is that even part of the vacuum circuit? and it seems freakish if that hole just all of the sudden appeared. i dunno.
i'm stumped.
any ideas would be appreciated.
thanks
i'm stumped.
thanks
![Auger motor not turning. not jammed, call light fine... Auger motor not turning. not jammed, call light fine...](/talk/proxy.php?image=http%3A%2F%2Fi1093.photobucket.com%2Falbums%2Fi436%2Fwesleyearl%2F008_zps1fb7db08.jpg&hash=8c27bcc1b6d4b02150bc3d7dfeb7e434)
