I have an older Whitfield Advantage pellet insert. I had an overfeeding issue one night and the auger mysteriously had stopped operating. I removed the motor and auger, carefully inspecting for foreign objects, bushing wear and so forth...nothing. Tested the motor and gearbox, which seemed to be operating properly, now all back together and working fine. Cause is a mystery.
One thing that I noticed is the end of the motor armature shaft is formed into a helical pinion gear to engage the gearbox. Didn't think about it at the time, but that armature appeared to have a whole lot of endplay in it...maybe 3/16". It occurred to me that maybe the helix isn't engaging fully any more because of this. Any thoughts on what the proper end play should be and what material I should use to make it proper?
