Just installed a new Enviro Empress and every once and while when the auger turns you hear a long drawn out sound like a creaking door. Is that the auger grinding pellets against the inside of hopper or is it the actual auger/gear mechanism?
jzinckgra said:.......you hear a long drawn out sound like a creaking door. Is that the auger grinding pellets against the inside of hopper or is it the actual auger/gear mechanism?
Flammam said:I had the same noises with Cornith. It seems they are Very hard and grind inside the auger tube.
Markcas123 said:Mine does the same thing based on which pellets I am burning. Hamer Hotones do it and the Hamer Stateman brand does it incessantly. I don't like them because of this.
