Old stone house (1700's vintage) . Basically a thick fieldstone and mud mortar shell, with a wood frame built inside for floors/ceilings. Space between second story ceiling and attic floor is sparsely insulated with blown in fiberglass, no air barrier.
Plan is to fill the small, uneven space between stone walls and wood frame with spray foam, and replace fiberglass with cellulose (both blown in). And, importantly, add a plastic sheet air barrier.
Finally my question:
Should the plastic sheet air barrier go on top of the cellulose and joists, or under the cellulose. On top would be easier, under would require lots of extra work, going over the plaster ceiling and wrapping each joist on the sides and top.
I may have just answered my own question, but I'd like some expert opinions on whether the air barrier should go above or below the cellulose insulation in the joist bays.
![[Hearth.com] Attic insulation guidance [Hearth.com] Attic insulation guidance](https://www.hearth.com/talk/data/attachments/271/271536-21fabd3a5e3fd377e5add709b576dd2a.jpg?hash=Fd0Fvk3Mf3)
![[Hearth.com] Attic insulation guidance [Hearth.com] Attic insulation guidance](https://www.hearth.com/talk/data/attachments/277/277835-8a39c7876e4af369d6e2667e103272ab.jpg?hash=7qfyxK9bg_)
