Sold for the $2650.00. The kicker is it's in the basement with the buyer being responsible for removal. Hopefully the new owner gets on Hearth here, Randy
I got the boiler . It was really hart to move it out of a basement. We had to put plywood on the steps and then carefully pull it out with the truck. By doing that, we made some damage to the metal sheet that has Atmos logo in it. I already send emails to order new parts to the dealers 10 min ago. Also I got the tank for $550 from New York. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150519375576&ssPageName=STRK:MEWAX:IT
Now I’m trying to find cheep Simpson chimney pipe to finish the project.
I didn't envy you getting that out of a basement! These are well made boilers & you are running with a Laddomat & storage so it will last quite awhile. I'm on my 2nd year with my 32GS so if you have some questions I can try to help, Randy/ PS you need to monitor flue gas temps & I keep a Magnehelic draft gauge hooked up to mine so I can keep it around .1 WC.
I got the tec support from the factory, and they told me that “120gal for DC40Gs is very little. It almost does not make sense to put it with DC40GS.“ BUT, I can go without storage if my “house has sufficient heat loss. If the heat loss of your house is lower then, we do not recommend that”. I’m confused now. I don’t have place to put more storage. My house is 3500 sqft now and I have dethatched garage 1200 sqft, but I’m not planning to heat my garage yet. Should I find smaller Atmos??
Andrey, when I saw the storage size I was wondering what you had in mind there. Mine is 720 gallons & I wish it were twice that! The Atmos should not be idled much & the 40 is a good sized boiler so its going to heat your house fast & then idle. If you have no room for 2 500 gallon propane tanks you probably should sell this rather than have it corrode out. Randy
