Hello
Does anyone have an issue with smoke coming out of the back flange? It can easily happen after a few years!
The Travis Avalon Astoria and Lopi Yankee Bay both have a heavy 4 inch exhaust flange to connect to 4" pellet pipe. The screws holding this flange are small and became loose after a few years on this 2005 model.
This flange does not go over all four sides of the exhaust blower housing only 2 sides, so extreeme care must be used to assure it is all sealed properly. The Archguard Optima PS1 pellet stove also has the same type of flange! it was worse and had a terrible smoke leakage issue but can be fixed the same way.
Also I recommend heavier stainless steel self cutting screws to hold better so they do not vibrate loose!
Some models have a heat shield that must be removed first, in order to get at the exhaust flange bolts. I use a small socket wrench with a magnetic bit holder to get in there.
See pics of Yankee Bay below:
Before putting the flange back on, it is a good idea to clean off any RTV, wire brush it and give it a coat of High Temp black spray paint for good looks.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Click to Enlarge:
Pic 1 - Removing loose exhaust flange was too easy! Srews were loose and RTV was all broken!
Pic 2-4 - Exhaust housing and flange - See top and bottom has no metal overlap
Pic 5 - Adding RTV -- Should be done to both sides, flange and housing
Pic 6 - New heavier SS screws vs old screws
Pic 7 - Cranking in the new screws which fit thru the flange holes but cut the housing hold a little large for a much better hold!
Pic 8 - Checking RTV to assure coverage
Pic 9 - RTV also applied to inner edge over weld to assure no leakage there (See Red Arrows) and around housing where flange is bolted. (See Blue Arrows)
Click to Enlarge:
