My Quadra-Fire Nova 800, 29 years old, has developed this symptom this past heating season. I’m running Green Supreme Northeast coast and see no negative comments in that tread.
The problem is that I start with a clean, empty pot and a flame 4-6 inches tall. 1 day later the pot is ½ full and 2 days later full with a large rolling flame blackening the glass. Almost no ashes around the firepot.
My exhaust runs horizontal 3 feet tee’s for a clean-out and turns vertical 15 ft.
What I’ve done:
1) Stove heat exchanges cleaned using the 2 rods.
2) Exhaust blower chamber vacuumed.
3) Stove pulled away from the wall. Both stove and pipe vacuumed to the tee.
4) Tee cleaned out. Vertical section tapped on to remove any loose debris. Did not cleaned with a chimney brush. If the small amount of soot on the walls are too much the vacuum switch should trip, it’s not.
5) Cleaned the chimney cap.
6) The feed rate paddle was almost closed. I re-adjusted that for a period of time and off setting that with the fire pot air intake plate. Both are about to where I started to again to achieve a 4-6” clean pot flame.
Any thoughts on where I should check next would be greatly appreciated.
What I’ve done:
