Hi all, I recently installed a used vermont casting aspen woodstove in my fireplace. It is inside an exterior masonry chimney, inside a 10" SS liner (for the old fireplace) and vented out with a 6" liner. The liner is 20' with a cap.
I do have a cold air intake that is venting in my basement at the moment (not currently hooked up). I placed a plastic bag over the pipe and cut a slit to limit the air flow. I do seem to get good burn times 8 to 10 hours.
My question is how hot should it run? Every time I load wood to tops out to around 700°F. Is this normal? I am not able to see the back of the woodstove but I can feel the damper and it is closed when hot.
On a side note, should I be able to open the door anytime and not have smoke plumbing out?
![Aspen wood stove temperature 700 too hot? Aspen wood stove temperature 700 too hot?](https://www.hearth.com/talk/data/attachments/307/307975-1409353ea653156b7e143cc0caca2ad3.jpg)
