Until I can find a better stove for my situation I have put my grandfathers old Ashley back to use.
From my previous insert install I had to cut a couple of ft off of the liner and install a tee. I have been using it for a couple of days and for one I am amazed at the heat output. It is very warm and I am getting minimal smoke from chimney so I feel like it is burning well. The problem is smoke spillage when loading door is opened. I have tried all the tips of opening primary air ahead of time I have even tried opening ash door and still when door is opened it is immediate spillage. I did a match test inside the stove and the draft pulls the flame up the liner and when a fire is going I can hear it drawing through the liner but when I open the door it stops pulling and spills out.
I used an adjustable elbow from the stove to the snout and I wonder if that is my problem. My question is would replacing the elbow with a straight section of black pipe help or is my issue something else. The snout is 10".
I talked to family members who remember my grandfather using it and they said it always did that, which I believe based on smoke stains on cabinet just above loading door, and one even made the statement all Ashley's do that, but I am not sure that should be the case.
I will attach pics excuse the furnace cement mess the pics were from before I cleaned it up. From the tee the liner goes straight up. It is a basement install.
Thanks for any advice.![Ashley C60 smoke spillage. Ashley C60 smoke spillage.](https://www.hearth.com/talk/data/attachments/172/172928-75acd02f0fc9588fff5df12086264e02.jpg)
![Ashley C60 smoke spillage. Ashley C60 smoke spillage.](https://www.hearth.com/talk/data/attachments/172/172929-c7a34419807431bd6042a5741e3410da.jpg)
