Ash in OAK
Utilitrack
332
Central ME
I just noticed this morning that there seems to be a 1/2" ask build-up on the horizontal surfaces of my OAK. I was under the impression that this is a once a year maintenance issue. Can I get away with just vacuuming the end of the OAK or should I open up the clean out on the inside. New Lopi Leyden PS installed on 10/10/08- have burned through 3/4 of a ton of Energex pellets. Clean out main chamber daily, perform thorough clean out 2 times per week.
Marc
Marc
Marc, I'm not sure I'm following you.....you say there is ash build-up on your Outside Air Kit? Not sure how that can be, since it's pulling air from outside your home......maybe I'm missing something here.
One way I can see this happening is, if the OAK terminates
above and or too close to the exhaust termination.
If this is the case I would correct that asap.
Sorry Macman- you are correct,I have a combo OAK and exhaust set-up, draws in outside air through a double walled system in same pipe as the exhaust. So it is the exhaust that has ash build-up. Sorry for the confusion.
Marc
OK, I got it now. Hey, if it's not too cold out, and you have the time to clean the ash out, then do it.....can't hurt. Keeping things clean on these stove setups can only help things in the long run. The clean "once a year" isn't written in stone......
I clean the exhaust as needed. Sometimes twice
a year, sometimes once. Depends on how much
ash the pellets leave behind. Like macman said,
nothing etched in stone about stove maintenance.
