OK, in a previous thread I talked about buttoning up the Tee on the back of my stove.
A little background...When I pulled everything apart, I checked out the stove pipe and chimney for buildup as my draft started to suffer at the end of last season. What I found is a little bit of flaky creosote in my pipe. I looked through the thimble as best I could, and from what I could see, the liner itself looks pretty clean. Now I'm thinking "jeez...there's not THAT much buildup, so what happened to my draft?". I decide to check inside the collar for buildup. This is a step stove and the collar extends almost to the front wall of the upper chamber (smoke rises through the back of the stove and then has to go forward to get to the collar opening). I reach my hand in, and there is a HUGE amount of ash buildup around the opening of the collar!! Definitely enough to prevent proper air flow.
Now my question...just when you thought "does this guy have a question?". Is this normal for an old stove such as mine? Also, I noticed the draft was affected after my lovely wife burned a crapload of cardboard one night. I wasn't here, but she packed the firebox full 3 or 4 times and just shut the door. Would all that cardboard cause the ash buildup??
Thanx in advance...
joel
Thanx in advance...
joel
