Previously I had a Kent insert that was sized for a 6" flue. I sized it down to 5" because the existing terracotta liner was 6.5"x15" ID. It worked fine for twenty years and then bit the bullet. So I bought myself a new Clydesdale, which also had a recommended 6" liner. Well I already had the 5" in there and it seemed to work so I figured I'd give it a try. You know what's coming next. It didn't draft enough. Dang.
So after a winter of no fires spring is here. I have a 21 foot interior chimney. I pulled the stove out and now am having a devil of a time getting the old liner out. My options as I see them are 1) Insulate the 5" liner with pour in insulation and hope that that improves the draft adequately. 2) Pull out the 5" liner somehow and hope that I can cram a 6" down there. 3) Try an ovalized liner. Do they make oval to round converters. 4) Go against recommendations and use the existing terracotta flue without a liner. 5) Sell the stove, which I love, and find one that will work with a 5" flue. 6) Hire a professional and let them figure it out. ??????????
