Hi all, I'm looking for a new splitter and was considering the 27 Ton Ariens with a Suburu Robins 169cc engine for $1599 at home depot and a 3 year warranty or the 28 Ton Huskee with a Honda GC 190cc engine and 3 year warranty.
The Ariens has a bit of a smaller foot print in that it is about 10-12 inches narrower saving a foot of garage space. It also has several attachments that can be purchased for it like a light kit. I also noticed that the oil reservoir is mounted parallel to the cylinder whereas on the Huskee, the reservoir is perpendicular to the cylinder and acts as the axle for the unit. It would seem to me that the Ariens design would put less stress on the reservoir. Although I think that the best solution would be to have a reservoir that was not integrated into the axle at all; even in the ariens, the back portion of the reservoir is part of the axle. However, I have not found many splitters that have a separate axle where the reservoir is mounted independent of the axle (sort of the like the engine is mounted on one side independent of the axle) in this price range at at this tonnage.
Any thoughts would be appreciated. If you have a better recommendation, let me know.
Here is a link to both splitters:
(broken link removed to http://www.homedepot.com/h_d1/N-5yc1v/R-100671189/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053)
http://www.tractorsupply.com/huskee-reg-28-ton-log-splitter-2152374
Thanks
Thanks
