alfio said:
Titan said:
Looking at various stoves on the web, i noticed that the Quad-Isle Royale, Harman-Oakwood, and Lopi-Leyden are all eerily similar to the V.C.-Defiant.-Are they being subbed out to one main facility for their basic castings? This question appears self-explanatory and may already have been posted here but this mirroring of stoves has just now caught my eye. :-/
I agree with craig , that they might look alike , but considering that harman's are assembled with gaskets , and not with cement which means that there stove must have tighter tolerances , I wold bet that there stoves are built by marso, they are the original company to build there stoves with gaskets and not by vermont castings . And has for the quad, it was built in Belgium by dovre , it was acquired by them, and Plus they all have different technology in them.
Better get your date straight the Everburn Encore has been made with gasketed seams for the past 2 years same with the non cat Defiant and many of the everburn dutch west stoves
I know for a fact VC has enamaled Harman stoves for the past 6 years. Since Harman has whearhouses full of stoves they decided to cut back the Plant expansion plans Originally They had planned to cast and enamal in house but cutting back they contracted VC to do their castings Why because it takes 4 months from order to receiving castings from Europe or The pacific Basin VC can have parts to them in 2 days.. VC also owns the bottom feed pellet stove paterns. That not the only company their foundrys cast for either.
The everburn technology is the same used in the Harman oakwood. Harman calls it Fire Dome. The Lopi Leyden also uses the same technology Quad at this time does not.
It is all basec on the horizontal burn pprinciple where smoke is drawn down pulled threw the hot coals injected into a secondary burn chamber which is also injected with super heated ait and ignited in that chamber simmilar to a mini gassification chamber temps can go up to 1700 degrees.
Guesswho installs the Harman gaskets?
