I like the design and how they "gasify" and force everything down through the wood coal bed to completely burn as much of the wood as possible.
I like diy projects and I'm wondering if one could take a used wood furnace similar to Wood Chief, Victor, etc. and remove the lower ash pan clean out. Line entire top and bottom area with refractory and just drill a hole between the two separations and place another plate of refractory to serve as a nozzle. And then force the exhaust to exit from the bottom chamber and through a tubed heat exchanger. It would otherwise be similar to other boilers (aquastats, air injection, pumps) but without all the electronics.
I was thinking of building a seton type boiler with the massive refractory and welding up a similar heat exhanger. But the more I sit and look at the YouTube vids of all the gasifiers, I really like the downdraft design with the intense torch like heat. So I can start from scratch and weld up the two chambers, doors, handle, etc. But after looking at the design, I'm thinking I could just buy a used wood furnace for less than 500 buck off of craigslist. It would save me a bunch of time and welding. So here's some questions.
Has this been tried and rejected because the standard firebox couldn't handle the heat? Or couldn't be make airtight very easily?
Can the Eko, Econo, or Tarm keep a coal bed without the every 6 minute "burst" of air? Or is the downward gasifier dependent upon the electronics.
Thanks for any input.
