Hello guys, My oil boiler has two hot water coils for domestic water and that is the location of the low and high temp controllers for the burner. My problem is that I need one of those ports for the aquastat to control the circ pump for the wood boiler water through the heat exchanger.
Can't I use a controller that has both the low kick in and high kick out on one controller instead of two? What one do you recommend?
thanks
thanks
