OK...so i think i am working out the kinks with my new Outdoor wood furnace except for one thing. I have two Honeywell L4006A stats on my unit. One labeled a Controller and the other a high limit. I have my Controller set at 180 with a diff. of 10 degrees. My problem is that that I can't get the water temp to get above 165 in the OWB. The weird thing is that my blower kicks off when I get to about 160-165 on the temp gauge. Could I have a faulty stat or would it even be possible that my temp gauge on the unit is bad?
What I do know is that after the water passes through the Heat exchanger and into my existing boiler that it only loses like 2-3 degrees from my OWB and my existing boiler temp gauges.
Just can't seem to get the water temp up to that 180 mark. Any suggestions or help would be greatly aprreciated!
