I'd like some feedback from anyone using a Laddomat, or even a termovar valve, and your results with the size of your boiler.
THANKS!
THANKS!
tuolumne said:I cannot speak from experience, only recent advice from several sources to be considered as expert. Tarm offers two systems for boiler loading, one is a Termovar loading unit which a similar to the laddomat. The other is a Termovar loading valve, coupled with a dedicated pump. They recommend the second option, as the pump would likely need replacing at some point. Mark at ahona steered me away from the laddomat for my EKO 40, indicating that it could not pump enough gpm for the size boiler and storage I have. I think he said the maximum was 13 gpm with very little head. I decided to go with a diverter (loading valve) by Danfoss and a dedicated pump. The valve begins allowing return water from the system when boiler water is up to 140 degrees. I believe the laddomat goes for somewhere around $270. A diverter valve and a Taco 007 can be had for around $210. Piping is virtually the same.
solarguy said:The valve I'm thinking about is made by Taco, model number escapes me at the moment..
If you look at Master's pic, the valve would go where the bypass is located, the sensor on the return piping near the boiler circulator. The valve is around 200, a transformer, 20.
A 1/2 or 3/4 valve would offer adequate low water return temp protection for any residential application.
I'm just not a big fan of mechanical thermal devices, sooner or later they crud up & fail.
Have a good Sunday!
gasifierwanabee said:you'll find that modulating 24v valve at http://www.blueridgecompany.com/radiant/hydronic/508
ABGWD4U said:gasifierwanabee said:you'll find that modulating 24v valve at http://www.blueridgecompany.com/radiant/hydronic/508
That look like an electronic mixing valve. It doesn't actuate with a sensor. Water temp is dictated by a knob on top of the valve.
Is that correct.
tuolumne said:ABG...I plan to pipe mine just like the diagram that master of sparks posted. The danfoss is 1-1/2" so I should be able to get plenty of flow through it. It seems to be a pretty foolproof system.
Someone mentioned corrosion inhibitor in the closed system. Any names I should look for? I'll have something close to 1200 gallons altogether.
