House is dry. Thought last winter about installing an automatic humidifier (such as Aprilaire RP-700) when I was heating with propane.
The Power Flow Thru Humidifer design seems to be a better way to go as opposed to the Bypass Flow-Through Humidifier. The Bypass Flow-Through Humidifier needs to be ducted into the cold air (return) supply I believe. Does that have any effect on the PF 100?
Another question I have though is in regards to the humidistat. Some models need to be adjusted manually and some are automatic with an outside temp sensor. With the outside temp sensor it seems that some do not work with a multi stage fan on the furnace (mine is a 3 stage).
Does anybody have any suggestions or comments on how these work with the pellet furnace? How about the humidistat?
