The first one shown is the one I am thinking about getting. Are these handy ? Accurate ? Needed ? Thanks.
http://www.condar.com/meters.html
Robbie
Robbie
I may be the wrong guy to answer this, because I have always run my stoves hot... in part because we only have softwood to burn here, and it burns faster hence hotter... In general, I look for where the stove's "sweet spot" is and run it there, regardless of what the meter sez. With the F602, that's in the 650-750 range on the top; with the Morso, it's more in the 550-650 zone, but it's a much bigger stove. And yes, sometimes it goes over that, but it's not a big deal.Robbie said:Can you tell me what temp. on your meter you consider time to pull back a bit or any other advice ? Or do you go entirely by meter ? Do you ever go over ? If you do, are you still in the safe zone and can easily control ?
Robbie said:Thanks for all the answers and information. This really helps and it's good to know many others have used this temp. gauge.
I will be ordering one shortly.
Todd, where do you put your "stove" gauge ?
Robbie
On a single wall pipe i would think not . The temps or going to be a little different . I would think the probe style would have to be used with double wall pipe . The flue thermometers are not going to do any good on a double wall pipe with out the probe . my .02tradergordo said:Is there any advantage or disadvantage to useing the "probe" type flue thermometers? Obviously they are going to give higher readings (no idea how much higher) - but you have to drill a hole in your flue (which doesn't "feel" right)
BrotherBart said:I have never understood why ya wanna know the temp in the pipe anyway. I have never seen any point of reference for what is a good pipe temp or a bad one. Now pretty much every stove manual will tell you what an efficient burn temp is measured on the stove top. Put the thing on the stove top.
The only use I see for the probe thermos is inserted into a cat chamber to know when to light off the cat.
If you go by the ranges on the thermometers for a pipe, the stove will be melting down by the time you get to the "good" range on the thermo with the newer stoves with cooler exhausts.
