I think I have a bad board component on my new-used vermont reliance 2430.
I'll post some info here for the next victim.
I wonder if that part is still available at stoveparts+. Not that it matters much, I will not pay $600 for it. I only traded a $100 pistol for the whole mess.
It didn't work when I got it home. Had a big ol rats nest in the open face shelf housing the mother board. A perfect mouse house. I pulled the board, air cleaned it, cleared out any more nest and wiped away the urine and feces w/an alcohol moist toothbrush.
Next I went thru the unit and chiseled creosole, vacc'd everything inside, oiled it by the book and sho-nuff it worked fine. Well it worked fine I think, I really wouldn't know. Is the double wall 3" supposed to get too hot too touch? Wish I had done a better job piercing the roof and checking clearances. I know this thing is inefficient but damn...
A year later today I started it up and the auger won't spin. I bypassed the board and jumped it with one of the dist fan power leads and it cranks just fine.
In fact I tried to just hook it permanently to one of the 2 dist fans. Thought was that one distrubition fan would operate in synch w/the auger feed rate, not a bad deal. This would disable a dist fan but its in a small room so I never used them anyway to save power. it works fine at first but it eventually overfires and trips the thermal limit or whatever is in there. I think I see a thermocouple also. I have to set it at half way to even engage the auger which much be too much juice.
What is in the side of the exhaust case?? A thermocouple and a ______?
I considered bypassing things and using a toggle but now I'm thinking that may skirt too many safety devices. After the hot pipes and kicken off I'm concerned.
And just for the record the inside of this thing is always filthy. Thing catches everything like a funneled dustpan.Its full of pet hair, dirt, dust, pellet particulates, and maybe some fly ash. This board will never be safe unless you encapsulate it in something to protect it.
http://www.stovepartsplus.com/Merchant5/PDFFILES/VC-PDFS/VC-REL-PLT-PDF/VC-REL-PLT-2340.pdf
I think I can send this board off to get it repaired for $65 to $150. A board schematic will lower the cost but I don't think that'll be in the O-manual.
TBC
