Shane said:Sounds like you have a fine stove, and an usupportive dealer. Let me ask you some questions about your Avalon.
Does it have a single or double door latch?
Does it have an orange rubber seal on the hopper lid?
Is the log placed correctly, improper placement can cause issues. (I do agree that an log set in pellet stoves serves better as an ash trap than anything)
Give me your ser# & I can tell if it is a stove that needs the airwash upgrade kit. Basically what happened is they re-desinged the air wash and it was drawing in too much air through the wash and not enough under the pot. It caused dirty burning and had to clean stoves very often.
Also explain your venting scenario. I have alot of faith in Avalon, I'd set one next to a Harmon anyday. In fact I've pulled Harmons out of houses replaced them with my Avalon and had happy customers.
As a for instance I ran the Avalon in my showroom for 2.5 weeks without doing anything to it except loading the hopper. All said it was a total of around 20 bags. I finally cleaned it out because I was embarrased at the amount of ash that was building up not because it quit running. In fact I haven't cleaned my Yankee for 1.5 weeks and I've run about 15 bags through it and I can still see through the window.
There is definately some thing contributing to your troubles and I would be more than happy to help find a solution.
Dave Anderson said:Shane said:Sounds like you have a fine stove, and an usupportive dealer. Let me ask you some questions about your Avalon.
Yes, it has a double door latch and orange rubber seal on the lid. The door latches were fairly loose when I got it, so I've tighened them down as much as I can and still be able to get the door to open
I assume so. My experience is that if it's not seated properly, it can easily tip over. There's really only one way that it will sit securely that I've found. I haven't used it in the past month anyway and probably won't.
My venting scenario is that the stove is connected to about a 3' flexible pipe that runs up the chimney, just past the flu. Supposedly, there is insulation that is stuffed in around it at the point of the flu. The top of the chimney is about 28' above the burn pot, so the draft seems pretty good. Most of the time, I run it on the "#2" heat setting with the vent stop pulled out to about 3.5. After about 3-4 days, I have to pull the stop out to 4.5 or so. At about 5 days, I have to shut it down to clean it with a shop vac.
Here are my main issues:
- So much ash in 5 days that when I open the door, it falls out on the floor
- A great deal of maintenance involved every week to clean it all out
- On occasion, stove goes out for no apparent reason (auger fault light blinks)
- Glass becomes so opaque with creosote that it's hard to tell how full the ash pan is (2-days with Energex, 5-days with Pinnacle Fir)
I suppose that I wouldn't be too unhappy if I never knew about my Mom's experiences with her Harmon. She just emptied the ash pan on Jan 18th all the way from Dec 23. This is from burning one bag per day on medium heat, glass windows as clean as can be. It's just frustrating I guess.
I'll try to find my serial number. Not sure where to look.
Thanks for your input.
Dave
