anyone out there clever enough to make a
jeanw
404
ky
killer that makes an adjustable sound killer that will blow out mice brains or stuns them so I can grab them and take their useless oood for nuttin bodies outside and smadh them flat with a brick and toss them in the woods. The A holes think they own the place they are so brazen they come out and run around the house even daytime, Dont even mention a cat. I dont want anything I have enough to take care of myself anymore.
I try not o leave anything out for them to get into..
Yeah i know about those plug in devices. Iread that the A holes get used to the sound. The New Victor mpuse traps work but they ( A hole mice) are too smart to go to them. I have to keep everthing in jugs and container . I have even hd some out in detached garage and they chewed a whole in a platic container
The A holes even chew there way fo off those large glue traps too.a
PLEASE PRETTY please I knoq there are many geniuses on this DIY forum.
Yeah I believe in the 10 commandment but I exempt bad bugs, mice .Moles chipmunk and rats and rat face squirels. This is coming from a true vegeterian. No vompsion for Gods creatures there. I hear one Now Rah Rah
Oh Blessings to all fellow members too and Peace on Earth
consistently of say Tuppeeware They even after chewing hole in the corner of container finishing all off and even leaving poo inside the still sealed top platic square continer.
So "I HATE TOSE MESES TO PIECES" Yall can make a fortune Guys and Gals. Ill be your first customer as long as it not out of sight pricing.
Im pleading yall Im d sick of the Brazen A holes
5gal bucket. Drill 2 holes at the top, 180 degrees from each other. Slide a plastic or wooden dowel through. Make sur it spins freely. Smear some peanut butter on the center. Fill pail with a couple gallons of water and make sure they have a way to get to the top of the bucket. St in a corner where they are sure to investigate. Empty and refill as needed.
Only way we control rodents on our small farm is, bait stations with good bait. We use Prowler soft bait. Traps in our case are close to worthless. Make sure to use stations and the posts that come with it to prevent translocation and poisoning untargeted species. We use several rat stations with larger holes and a bunch of regular stations. Stations we use are tomcat outposts.
This guy is the king of mouse trapping.
Reactions: stoveliker
This is his updated trap.
And here is a free trap if you have a bottle like this.
Living on a farm we get lots of mice and star-nosed moles
we do not kill them but just use a product that repels them
from the house. This works well and is environmentally friendly
You can make your own.
72 mouse traps for $37. They’re cheaper if you look for them.
Find and seal any holes you can. It’ll save on heat loss too! Put enough traps out and you can even find the hard to locate holes. Peanut butter works fine as a bait. There’s no need to get fancy with traps.
I also use Victor traps in the basement. Drop the dead mice just off the driveway. Reuse trap. Think a fox picks the mice up.
Up until a few years ago, we had constant mouse ingress in our log cabin. The problem was worsened because we only get up there once every month or two. We used snap traps. The best snap traps we found were Snap-E traps.
They work great. Easy to empty, easy to set. The problem for us was dead and rotten mice.
It made the cabin a place we did not enjoy spending time at, or at least really reduced our enjoyment.
Finally I decided to fix the problem. I had a pest control guy come out and inspect the place. He told me everything I needed to do to eliminate access to the place.
We got rid of their food source. My dad fed the birds up there. All the seed (outside, shed) had to go in metal cans. Same with the suet. Eliminate their local food supply and they will have less desire to be around the house.
We got rid of stuff. My parents like to hang on to everything and used the cabin as a place to dump stuff they no longer used. The more stuff you have, the more places mice have to live and hide. The more stuff you have in your way, the harder it will be to access everywhere you need to in order to fix the problem.
Then I sealed everything. It took weeks worth of weekends. I pulled all the window trim. Filled all gaps with a stiff caulk. Filled large gaps with metal hardware cloth and spray foam. The roof vent was pulled off, and hardware cloth stapled under it. Added a chimney cap with screen. I sealed any log gaps and access to the roof insulation. When the outside was done, I did the same inside. Replaced the stove cleanout door with one that sealed. Hardware cloth and spray foam everywhere they could access the interior through the roof/ceiling insulation. More caulk.
Any hole or gap bigger than about 1/4" needs to be sealed.
We have not had any mice in the cabin in over three years. It can be done.
We have had half a dozen or more suicide mice jump down the chimney and end up in the stove cleanout or the wood stove, but they can't get into the cabin because I make sure the stove inlets are closed every time we leave. The cap screen has a good sized mesh. It keeps birds out, but I guess not mice.
They got into the direct vent propane furnace, but could not get into the cabin through the furnace. I wrapped more hardware cloth around the inlet/outlet of the furnace so that has not happened since.
There will always be more mice. You cannot trap or poison them into submission.
well bought lots of those newer Victory traps unfort they are gray now and j harder to see now instead of beige. wemount them on small pcs of say a 3/4 board so they cant drag them awy like glue traps etc. but its all a pain in the butt esp w ith my bad Seeing now. Also the moles outside are OBSENCE a virtual tri[pping hazard everywhere. There is prob more ferals out there outside but they dont do much good. I dont want to maintain any livingi creatures anymore Maybe a compactrobot dog outside or a Laser gun for moles and tree rats etc and a robot compact cat inside. HA HA Inn garage can use pellets. but they so smart they ignore or hide the stuff.
Rather have so great Soundwve thing to explode their ASS hat Brains, Thanks all
The best trap i have ever used is a electric trap off amazon. I killed so many in the first few months i burnt the thing out. Some peanut butter inside and their must have been a line up of mice.. Could also get yourself a cat
Don’t forget a box of latex or similar gloves. I dont use a mask handling traps etc. but it wouldn’t be over kill. Recently Hantavirus did take Gene Hackman’s spouse.
