anyone make a woodfired kiln?
schwaggly
Burning Hunk
198
n.shore ma
has anyone made a small woodfired kiln, or kicked the idea around? I've got some wet oak on my hands and some time so why not?
I plan to make a solar kiln next summer.
Adios Pantalones said:
You mean a wood fired- wood drying kiln I assume. There are at least 2 of us here that have made wood fired pottery kilns.
yes, thanks for the clarification.
Wood fired wood drying kiln??? That's just sick and wrong. :-/ :cheese:
not really I would burn off all my punky and crappy wood to get my oak ready to burn before 2011/2012. I just sold the wood stove with blower that I was going to use for my kiln. I think it would be a cool experiment. What could possibly go wrong?
I have made a wood fired kiln inside of my pole barn, the room is about 12' X 20' and holds 2 full cords of firewood, I use a large woodstove and burn about 1/3 of a cord a week to heat the room, with temperatures ranging from 120-145 degrees, depending on ambient temperature. I normally can't dry it fast enough for customers needs. I stack the wood in boxes I have made and can move them around with a pallet jack. It usally takes about a week for each load.
  • anyone make a woodfired kiln?
That's an interesting setup! Do you start with wood that was just split and mostly green?
those are huge, way bigger than I was thinking. I would probably max out at 1 pallet at a time. I would only be drying my personal stash and doing it as a fun project.
JJWOODCUTTER said:
Yes, I usually cut up and process the wood as my supplier brings it. I will take some pictures of the actual kiln and post them.
thanks looking forward to viewing your setup
Hi JJWoodcutter, where are you located in Central NY?
check out this CL ad this thing would be a great start for a kiln
http://boston.craigslist.org/sob/zip/1528720258.html
Date: 2009-12-29, 9:05AM EST
Reply to: [email protected] [Errors when replying to ads?]
Hi Everyone, I am replacing a rotary oven that is in my bakery. I need it out so i can install the new one ASAP. Do you want it?
U move it U got it for Free.
It is working now. It hold 35 full size sheet pans.
It is Natural Gas fired. Just come and remove it and it is yours.
I can take pics if needed, there is wear showing on the tray arms
here are some pictures of the kiln, and what the wood looks like when taken out of the kiln
