Anyone make a heated roller for roofing?
glenlloyd
164
des moines, IA
Hey all
I just 'shingled' my garage with 3 tab Owens Corning Supreme as siding. Rationale was that the color matched the brick of the house pretty well and I couldn't afford to put a brick veneer on the garage...enough said.
Anyway, hanging vertically it's a pita to get them bonded with the course below via the seal strip and I don't have the time to do them all with the heat gun. Does anyone make a heated roller that you can use to seal these things down? I'm concerned that the longer they aren't sealed the more likely they are to break off.
Looking for something that will help me to get these sealed down (cured) before winter blows in....which isn't too far away.
I'll post up a pic later so you can see what it looks like.
Thanks
Steve
Heat gun is your best bet. Do a few at a time till you finnish.
I'm not sure I could do the whole garage with a heat gun, it's completely (or will be) covered in shingles.
steve
Hope you mailed them really well. Chances are they may come off anyway. Ain't made for vertical installation. The weight of the shingles alone can cause them to tear around the nails.
Hope they hold up for you.
I did a typical nailing pattern on them. Shingles were actually applied quite frequently years ago, there are still several houses in my neighborhood with shingles installed in the gables and around dormers where I assume once there was cedar. Out in the rural areas where I grew up it was common to see garages covered in asphalt roofing material of different types.
My main concern is getting the shingles to bond to one another efficiently. A heat gun would take forever for this process and hanging vertically they never will bond without assistance. If I can get them to bond then the likelihood of the siding staying in place would be far greater over the long term.
Looks like I'm going to have to invent something to help with the bonding situation
thanks
steve
I just can't get the ill-fated image of you up on a ladder w/ a torpedo heater trying to get this done.
I understand your frustration, no matter what you try, just double check yourself and make sure what you are attempting is a good idea rather than one out of frustration and determination!
All you need is one sunny summer day! Certainly can be frustrating.
pen
pen
haha....torpedo on a ladder. I have one but wouldn't dare lug it up on a rickety ladder to get this done. I have plenty of sun, but that does no good since there needs to be reasonable pressure applied along with the heat. I could get by on the south and west with a simple roller if the sun were out in full force, but on the north and east it's a different story. The east is blocked by the house for most of the day, the north is bad for obvious reasons.
A friend of mine built an infrared heating element for stripping paint from wood trim. I've contacted her about borrowing it and I'll work up something to mount it to a roller so I can push the thing across the surface heating the surface and then forcing it down.
I've hand pressed some on the south when it's sunny out and it seems to work ok, but our temps are going to be dropping some so I think the heating assembly will be necessary. On the ones I used the heat gun it worked solidly but only by lifting and directly heating the seal strip
We'll see how this goes!
steve
how hot does it need to get? could you tent the side of the building with a tarp and use the torpedo as a heat source for the entire side of the building?
The camp I tore down to use some of the wood for my woodshed had shingles put up as siding . . . surprisingly enough they did pretty well . . . many were stuck together due to the sun's heating action . . . I was able to save a few though which I also re-used or re-purposed for my woodshed roof . . . the sun may be your best friend in this case . . . but as you say . . . we're kind of going the wrong way for those nice, warm days.
You could try a good fire in a barrel, and fashion some kind of tool with a flat metal end and a good handle to insulate from the heat. Heat the end of the tool and run under the tabs along the tar lines.
Maybe even a regular metal rounded edge roofing trowel with a handle attached. Heat in barrel full of burning wood etc, and run underneath the tabs fast enough not to melt the shingle itself, but slow enough to heat the tar lines and press in place with the other hand following along sliding across the tabs faces to pressure the tar strip to the tabs. Wonder if an old iron would work somehow? Just a thought.
The other option id get a 5 gallon bucket of asphalt roof cement and a trowel, and run a bead or few dabs under each tab pressing into place afterward. Be warned roof cement or muck as we call it, can get real messy if your not careful.
Amen brother . . . whenever I've used this stuff I tend to get a quarter of it where I want it to go, a quarter smeared on the shingle where it shows and half on me and my clothes. :)
Doesn't this now come in caulking tubes? I know Black Jack does but that would seem it would be very expensive to use Black Jack. I thought that I saw muck in the tube at a BBS either HD or Lowes.
Shawn
Solar seal 900 Is by far the best roofing caulk I have ever used 5 or 6 bucks a tube. it would out last the shingles. A dab or 2 under each tab would work I think.It has lasted 15 years on my roof with no sign of cracking or coming loose exposed.I can only guess it would outlast the shingles being under them.
Blackjack or similar in tubes is going to get pricey. And unless it is good and warm to soften it up, your hand will be cramped from pumping the caulk gun after about a row of shingles.
The muck is easier IMO to put on, and less chance of it being harder and therefore not compressing enough to let the tabs fully contact the shingle area underneath. Now you have tabs that are slightly lifted away from the shingle underneath allowing for wind etc to blow up there and possibly tear the tabs. Also, if the tabs don't sit flat, in the summer they might heat up enough to sag around the blobs of blackjack and you will see a zillion bumps all over the area. Pumping a caulk gun under all those tabs is going to give someone Popeye forearms, but most likely some very sore and tired muscles. If you do use the tubes, put them in you furnace room so they warm up and flow easier, thus pumping the caulk gun easier and making it easier on your arms & hands.
They do make power caulk guns nowadays also, most run off chargeable batteries. Not sure the cost is worth it or not.
