Iam useing a furance very large fire boxkarri0n said:As far as a woodstove goes, I wouldn't recommend it. Same issue as burning pellets as the primary fuel in a woodstove, the airflow just isn't made to do it. Plus, it very well may just be like filling your stove with 1-2" splits; 15 minutes of 4000 degree firebox followed by a mess of ash.
I can set my draft inducer to blow under the fire fairly eazyAdios Pantalones said:The problem will be that they will smoulder and not get air in there. Controled air flow from underneath is required- like with coal or pellets.
my neibor just trim all his tress 6 ackers worth piles and piles everywhere he is going to rent a chipper thought I might just have him dump it on my landWoodcrib said:Give it a try with some small and mid-sized splits. Let us no how it works !
Are you getting these from a tree Company !
lol,but thats about right more trouble than its worth!ManiacPD said:Yes. I know of one guy who is burning chips in a highly modified New Yorker wood boiler. It hasn't been cheap I'll tell you that.
Most wood chips have 30-35%% moisture. Just like green wood, it takes a lot of Btus to remove that moisture, before you get any appreciable gain in water temp (talking boilers here). It takes a ton of air to get combustion and it needs to be fed continuously or no fire.
I like my chips bigger - 10" diameter, 18" long, and as dry as I can get!
Adios Pantalones said:They won't dry in a pile- they'll compost. Find a good way to dry them passively and you're golden.
Standing each individual chip on its end could be painstakingly slow.karri0n said:Adios Pantalones said:They won't dry in a pile- they'll compost. Find a good way to dry them passively and you're golden.
Exactly. Make a Holz Hausen out of wood chips...![]()
We're just putting the finishing touches on a 90 million dollar biomass boiler which is designed to use 50% or better MC. This puppy will burn upto three B-train loads per hour. There are concerns of spontaneous combustion of biomass storage piles from the heat of decomposition.Dunebilly said:Moisture content doesn't actualy matter...
