I have just made my first foray into home canning and had a question that doesn't seem to be covered in my "Ball Blue Book". I didn't know if anyone here might be able to help figure out what I did wrong, and if my product is safe...
I got a big bunper crop of hot peppers out of my garden this year, ended up with nearly 5 GALLONS of everything from Habs to Super Chilis to Cherry Bombs. I just wish my sweet peppers had done as well.
I ended up making a bunch of basic hot sauce with most of the peppers (I also did several other variants in smaller quantities that went in the fridge) - Hot peppers, Garlic, Onions, Red wine vinegar, and Salt. This was simmered for a while, then pureed in the blender. The result was a nice red sauce with good flavor and serious but not overpowering kick. Since I had a couple gallons of sauce, I decided it would be best to experiment with canning some of them. I have a water-bath canner that I use for melting honey, and I'd picked up an old copy of the Ball "Blue Book" home canning manual. I bought a bunch of jars w/ lids, and rings at the local hardware store, and figured that this should be a no problem item since the vinegar base makes it extremely acid.
I didn't mess with sanitizing the jars given that it was an acid base food. I filled the jars with the simmering sauce, using a canning funnel, and filling to the bottom of the funnel spout, which left a head space about even with the rib below the jar threads. I put the lids on and hand tightened the rings, then put them in the canner - which I had filled with water and started to heat about the time I started filling jars. The water when I was putting the jars in was warm, but not at all hot. I had some trouble getting the jars to stand up properly, several fell over and I had to keep standing them up, but eventually I got them all upright.
I eventually got the water in the canner to a boil, and processed at a rolling boil for 10-15 minutes, then turned the heat off and pulled the jars out. Every single one pulled the top down tight within about 5-10 minutes.
After they had cooled for several hours, I examined them, and noticed several of the jars now had little or NO air space in them, and appeared to have a layer of water under the sauce. Other jars had about the headspace I started with. I'm confused... :-S
There was nothing that sounded like this in the troubleshooting section of the Ball book, so I'm not sure exactly what went wrong.
My theory after thinking about it for a bit is that I had filled the jars with hot sauce, then put them in a pot with much cooler water in it. Is it possible that the water cooled the jars enough to create a vacuum that pulled some of the water from the canner into the jars?
If so, is this food still safe? Anything in the jars was definitely processed, and the jars are sealing properly - not to mention that there aren't many bugs that could survive my sauce.
Advice appreciated....
Gooserider
![Stick Out Tongue :p :p](/talk/styles/default/xenforo/smileys/raspberry.gif)
Gooserider
