I am working on an Empress insert and it shuts down after it goes out of start up mode when run on one or two. The auger lite flashes but the auger motor does not run then it will burn out. I did verify it is due to the vacuum switch opening, I jump the switch and it will stay running. OK so I thought this will be easy but I tested the switch and it seemed to work fine. Usually I work on St.Croix stoves and I am more familiar with them. I did clean this stove thoroughly about two weeks ago and it made no difference. I also checked the exhaust and brushed the liner, approx 20 ft 3" to the top. The thing that bothered me from the beginning is I thought that the stove seemed lazy, just seemed like not a lot of air flow but its a friend of mine and he said it always burned that way. Today I put a MAG gauge on it and have very low vacuum readings .02" at the sensor hose, the spec is .09-1.3 Checked the hose and fitting both clear so I referred to the service manual and all the voltages are low at the exhaust blower. I should have 76V on #1 and I have 55V however this would be with 115V line and I only have 106V line voltage. The manual says to replace the board but my friend had replaced that already and it did not help I don't see any air leaks and doors close tight. I just does not seem to have good exhaust flow, the combustion fan runs and the motor seems ok, it runs smooth and quiet. Maybe too quiet it seems so slow but I am not sure what is normal here. Any input would be appreciated I hate replacing parts unless I am sure. Thanks
