Another wood stove heating water question(s)
newguy08
27
Southern Tier NY
I have read all of the posts regarding converting a wood stove to be able to heat water for residential heating. Many of these posts reported good luck. I am looking to convert my wood stove and have a few questions to those of you who have some experience.
1. Have any of you placed the steel tubing in the "air channel" which circulates the warm air instead of installing into the firebox?
2. If not, does anyone have any reason to believe that this might not be worth the effort due to decrease temperature or?? ( I had thought of this so not to cut into the firebox itself.)
3. With all of the information about hooking up a circulating pump and using pressure relief valves, I have not read anything about what happens to the system once the thermostat reaches the set temperature? With my gas boiler it would shut down and stop circulating. What happens in this situation as the water within the steel tubes would still continue to heat? Would you set the thermostat to a higher temperature to keep the circulating pump operating?
Thanks
Thanks
Are you reading the same posts we are? The vast majority of the posts that *I* have seen seem to be saying poor to mediocre results... Not to mention the issues of code compliance, voiding stove warranties and UL listings, etc...
No answers to your first two questions, the answer to the third is that if you don't maintain circulation at ALL TIMES when the stove is running, you will find out either just how your pressure relief valve works or how your stove looks in orbit... This includes not only when any heat loads are satisfied, but also any possible pump failure, power failure, etc... You MUST have some kind of provision for gravity circulation that can get rid of the heat produced by the stove, or some other form of heat dump that will do the same thing...
Gooserider
