I have been doing a fair amount of reading and searching for pellets for this winter. Here is what I initially found:
Cheat River (Lowes) $197/ton
North American (Lowes) $197/ton
American Wood Fibers (HD) $197/ton
Greene Teams (Pellet stove shop) $300/ton
Lignetics (Pellet stove shop - they weren't sure if Green label or Blue label) $300/ton
I currently have about 20 bags total. These include the Cheat Rivers, North Americans and AWF's bought recently. I also have Great Americans from last winter.
Then I found two other pellet shops that are not very close, but have better pellets. They have:
Store 1 - Hamer's $270/ton.
Store 2 - Hamer's $255/ton
Lignetics $239/ton
Okies $319/ton
Turmans $245/ton
Energex Power Pellets $245/ton
Store 2 is a good hour and a half away from where I live, so I will need to borrow a friend's truck and pick them up.
Store 1 is closer, so I thought I would go there and pick up a few bags of Hamer's to test out. I called the store on Saturday to confirm they had Hamer's in stock and learned that although the price is $270/ton, if I buy less than a ton the price is $7/bag.
So, I am thinking about just "biting the pullet" and picking up a ton without any testing.
If it helps any, we have a Harman XXV that sits in the corner of two exterior walls. The vent runs straight outside and then goes four vertical feet. We also have an OAK installed. Also, I pre-paid for a ton of pellets last Spring that I can pick up as needed from my local hearth shop. They usually carry Lignetics, but currently have Greene Teams. We don't run the stove as much as many of you, so this will be enough for the winter.
EDIT: I should have added that my theory on this.... I intend to use the bags that I currently have, along with the ton from the local hearth shop for early and late season. This (to be purchased) ton would be used in the heart of the winter. I am curious/tempted by the Hamer's, but am tempted to test the infamous Okies.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Lignetics $239/ton
Okies $319/ton
Turmans $245/ton
