I am trying to ID a wood burning insert. Got it for $20 and a school fundraiser auction maybe 15 years ago. It has no manufacturer markings on it anywhere, I've looked carefully multiple times. Only markings are two metal tags, one is a warning to avoid creosote fire and overheating, the other is a warning that it might be hot., and to see the nameplate. If it had a nameplate, I wouldn't be asking
Measures about 27" wide, 18" deep, 22" high. Made from plate steel, not cast. (edit - door is cast, rest is plate) Has firebrick inside on the bottom, and on the front between the door and the bottom.
![another stove/insert identification request another stove/insert identification request](https://www.hearth.com/talk/data/attachments/218/218352-2b9eeea6040345214136e9e8dac85ec9.jpg)
![another stove/insert identification request another stove/insert identification request](https://www.hearth.com/talk/data/attachments/218/218353-965eda853f315c2a68f12f920d2e8a0e.jpg)
It has a single door with glass panel, hinged on the left.
Air intake is set with a slider under the door. Air output is a full width rectangular opening along the top.There is a dual squirrel cage blower, a Dayton 4C826. There is no built in blower speed control,the wires to the blower end in a standard three prong plug. it came (to me) with a "POW-R PLUG III" motor speed control, which seems to be for ceiling fan speed control, but works ok with the Dayton blower.
Inside, top rear there is a metal box, which contains a bypass flapper connected to the rod that comes out the top right front of the stove. The opening on the front of this box is 9-3/4" wide by 3-3/4" high. There are two bolts sticking out form the front of it 13" apart, Those bolts must be there for a reason, seems like there is a part missing from the front of that box, perhaps a catalyst, perhaps just some baffle.
![another stove/insert identification request another stove/insert identification request](https://www.hearth.com/talk/data/attachments/218/218354-fe5015d71780120b1276bb1efb8527bc.jpg)
Haven't used it much, not pretty but it does OK. Always figured I should try to figure out what internal part is missing, finally getting around to doing that, with the goal of using it more
Thanks for any help
Thanks for any help
